Or a leaking exhaust valve.
If you do have an exhaust valve leak, this would be an excellent reason to upgrade to a nice set of aluminum heads and intake, along with headers, a stroker kit, cam, carburetor, ... I'm sure there are lots of knoweldgeable guys here who can help you spend your money
BTW: I've got one of those cylinders too. Since it's the exhaust valve, I'm just driving it.
The cost to replace the valve seats, and complete a valve job, just doesn't make sense for the slight loss in fuel mileage and power. If the valve job gets done, it wont take long to suck the oil right past the old rings, and start oil fouling spark plugs.
It could be as simple as coking around the valve stems, but opening up an old engine like this, is akin to opening a can of worms. To me, it seems like an all or nothing proposition. It starts innocently enough with a leaking valve, moves on to drilling out broken exhaust manifold bolts. Then might as well throw new seals and gaskets at it.
Well, now I've got the thing apart and on the stand. Next thing I know, I'm ordering up all the goodies to build a full on tree trunk pulling, trailer hauling, deisel eating, angry big block. When it would have run just fine for another 10 years...
This is why I'm not even fixing the valve cover gaskets. I can't trust myself.
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
