Dynamic Compression Ratio- Conflicting Numbers
dustman_stx
Post by dustman_stx »
So, I'm trying to determine the DCR of my engine. Keith Black ( http://www.kb-silvolite.com/calc.php?action=comp )and Wallace Racing ( http://www.wallaceracing.com/dynamic-cr.php ) are both showing a DCR of ~7.5. This is on the low side for performance I understand. But the Wallace page also gives a cranking compression of 145.5 PSI. I just checked my engine and got 175-177 PSI on every cylinder (except the ones with the blown head gasket :oops: ) This cranking PSI would indicate a DCR of 8.5 or so, I think. Anybody have any ideas? I have checked and rechecked my numbers: 4.080 bore, .040 gasket with 4.230 gasket bore, .010 deck height, 5cc pistons, cylinder head volume 72cc. I'm putting in 72 for IVC degree number, which is what camquest lists as seat to seat. I am running .020 lash, so should I be taking that out? When I plug in 50 degrees which is the .050 timing, I get right at 175 PSI cranking compression, which is what I'm at.
Edit: 6.490 rod length.
Brokenarrow
Re: Dynamic Compression Ratio- Conflicting Numbers
Post by Brokenarrow »
Try this one, you use your cam duration and lsa, or intake closing angle.
http://www.projectpontiac.com/ppsite/content/view/16/30
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
Are the 5cc pistons and 72cc heads measured numbers or based on what they are supposed to be?
dustman_stx
DuckRyder wrote:Are the 5cc pistons and 72cc heads measured numbers or based on what they are supposed to be?
I am assuming on the heads, but they should be within a few cc's of that according to research I've done. C8AE-H heads. 5cc is correct for the piston.
dustman_stx
Brokenarrow wrote:Try this one, you use your cam duration and lsa, or intake closing angle.
Plugged the numbers into that one and still got 7.66:1 DCR. That would still give me around 145 PSI cranking comrpression, yet I'm running 175-177 PSI. :hmm:
Use 68 for the heads and see what you get...
dustman_stx
DuckRyder wrote:Use 68 for the heads and see what you get...
Had a buddy tell me that Comp Cams are advanced 6 degrees. Plugged that in with 68cc heads and got 7.97 DCR, 10.66 SCR. That DCR would still put my cranking PSI around 155. I plugged the numbers into the Wallace Racing calculator and got 8.29 DCR, with a cranking PSI of 166.48, which is still about 10 PSI low.
DCR is an inexact science, the Silvolite one in particular usually differs from other calculators. There is one that you have to download and is widely belived to be the most accurate.
As with any other calculator, the better the numbers you use the more accurate the results. heads blocks and pistons all vary from specification and really the best way to get them is to measure your engine (including degreeing the cam). If the block and or heads have been decked in the past it could account for your discrepencies.
To what end are you attempting to calculate this, you mention blown head gaskets, but does it spark knock or exhibit some other problem?
dustman_stx
DuckRyder wrote:DCR is an inexact science, the Silvolite one in particular usually differs from other calculators. There is one that you have to download and is widely belived to be the most accurate.
No other problems. Runs strong. I have decided the blown head gasket was my fault for using old bolts and not using an assembly lube. Just checking myself to see if my components were a good fit, as I didn't understand or calculate DCR when selecting components. Based upon my crakning compression and the way it runs, I'm thinking I have a pretty good setup. Thanks for the help.
