302
2fast2furious
302
Post by 2fast2furious »
its already a hot motor!! i just wanna know if any one has some suggestions on wat i should do to hop it some!! i have some ideas i just want some input!!
grease stains, oil spills, and hard work= one happy southern boy!!!
Vinniesempire
Re: 302
Post by Vinniesempire »
stroker+turbo+yates heads=awesome
2fast2furious
Re: 302
thanx man
Vinniesempire
Re: 302
what are your ideas?
2fast2furious
Re: 302
well im puttin aluminum eldlebrock heads on it, edlebrock high proformance cam, 4 barrel intake & carb, and msd ignition system!!!
papabug71
Re: 302
Post by papabug71 »
Solid lifter cam with crazy duration..? Nice stall & correct gears to match the cam+stall. Dont for get to do the exhaust. Long tube hedders 2 1/2" pipe, free flowing mufflers & a x or h pipe (your choice).
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
cep62
Re: 302
Post by cep62 »
:yt: Then put it in a smaller lighter vehicle.
If you want to move our heavy trucks you should have more cubes. :2cents:
OldRedFord
Re: 302
Post by OldRedFord »
What are your goals? Just more power?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
papabug71
Re: 302
Post by papabug71 »
I dont know guys, my 302 moves my truck pretty dang good. & Its bone stock.
I would like to see what a really hot 302 would do in these trucks.
Matt
Mine since 5/7/'94
taylor351
Re: 302
Post by taylor351 »
The 1969 mustang weighed around 3400-3500 lbs. Our trucks weigh around 3800-3900 lbs. The heavy truck argument does not hold water. Power to weight ratio is what you are looking for. If you are talking about a fully loaded f100 then we are talking about 4900 lbs. If you are hotrodding a fully loaded f100, don't it is too hard on them no matter what your motor is.
Edit: In 1969 the 302 was ratde at 210 hp and the 360 was rated at 215 hp.
Keith
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
cdeal28078
Re: 302
Post by cdeal28078 »
taylor351 wrote:The 1969 mustang weighed around 3400-3500 lbs. Our trucks weigh around 3800-3900 lbs. The heavy truck argument does not hold water. Power to weight ratio is what you are looking for. If you are talking about a fully loaded f100 then we are talking about 4900 lbs. If you are hotrodding a fully loaded f100, don't it is too hard on them no matter what your motor is.
Keith
The 71-73's probably weighed 4oo pounds more than the early Mustangs. I had a 72 Sportsroof for a while with a pretty mild 351w. Had a close ratio 4 speed in it and that thing was scary fast. A 302 would have pushed it very well also. Little bit of work on it and that 302 would have been faster than the 351W. These trucks are not that heavy.
I had a mostly stock 351w in my 71 F100 Long bed and it went 10.00 in the 1/8th with me spinning halfway down the track and not knowing squat about drag racing. lol
Sure a 302 is not going to be much good at towing 10k on a daily basis. I did tow that much once or twice when my F100 had a 302 in it and it sure did suffer. lol
I did pull many a trailer with cars on it and probably a couple hundred loads of firewood. Did all of that fine with a 302.
Just got to know your limitations.
Hey Keith. Long time no talk.
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
