Parking Brake Cable's
Georgia71
Post by Georgia71 »
Hello to All,
I replaced my parking brake cables on my truck and can't find the clips. The ones that hold the cable to the frame. The picture I have is kinda fuzzy. Sorry. I tried napa and the guy said he didn't have it. One cable came with it the other didn't. I guess I could go back to where I bought it and tell them one had missing parts! Didn't think about that. I tried one that holds the front brake lines but it seemed too loose. The one that came with the clip was a round wire type clip. Kind of shaped like a horse shoe. It's the cable on the drivers side in the picture.
Ga71
Georgia71
Re: Parking Brake Cable's
Post by Georgia71 »
Here's where the image is at from the last post. Sorry
Ga71
http://s442.photobucket.com/albums/qq14 ... ecable.jpg
convincor
Post by convincor »
you'll probably only find this style but they'll work
http://shop.advanceautoparts.com/webapp ... 1196237___
Otherwise McMaster Carr- http://www.mcmaster.com/param/asp/PSear ... nWidth=810
"Still Plays With Trucks"
Georgia71
Post by Georgia71 »
That's the kind I got at napa. But it fits too loosely.
Ga71
convincor
Post by convincor »
loose as the hole being to big or not holding it tight to the frame?
Just as a point, there what came with a replacement Wagner cable, and there what is use on my 71 frame that has the OEM cables.
So you may just need to squeeze them a little to get them to stay.
If not holding tight to the frame, put a spring washer on the cable side then assemble.
knightfire83
Post by knightfire83 »
They are called External Hitch Pin Clips, should be available at a hardware store.
1970 Ford F250 4x4 ~ Sold.
Georgia71
Post by Georgia71 »
knightfire83 wrote:They are called External Hitch Pin Clips, should be available at a hardware store.
Hey Knight,
That's what came with one of the cables. I will try to get some at the hardware store tomorrow. The other flat ones fitted loose. If I have to I'll just squezze them in like suggested.
Ga71
BigBlueF250
Post by BigBlueF250 »
If you strike out, send me a PM. I have a bunch of the ones you're looking for.
Steve
yes i have some of those also.
Georgia71
Post by Georgia71 »
I dropped by lowes and picked some up. Thanks for the info.
Ga71
