i have a 1972 ford f250 v8 390 engine...it s stocked with manual steering...i went to a junk yard and pulled two differnet steering pumps one of which im sure will work.. i just need to right bracket...WHERE CAN I ET THE RIGHT BRACKET>>>>>>?????
Also... i pulled to steering geer box... now do you have to modify your steering column to fit appropriately to the geer box or should it fit right on??????????????
please help i would love to get some power steering on this puppy
column length modifications for manual to powersteering 1972
Re: column length modifications for manual to powersteering 1972
Go read in the tech/tutorial section and post back after you have read them.
When you were pulling the pumps, why didn't you pull the brackets? Its an FE engine, go find the brackets.
i have th e brackets they dont fit
If you do not have the firewall flange bracket for the power steering I will swap you one for your manual steering one.The one you need has"Power Streerng" stamped into it. It makes the column come out of the firewall higher up to meet the power box.
there are only two different bracket for the fe enigne. one is made up into 1970 and the other is made after or mid 1970 and up. if you have a small block engine you need the brackets from a small block engine. the column lenghts are as follows. the bendix steerign box requires the old type manual lenght column. which means you dont have to change your column just adjust it to fit via the botls under the dash. the saginaw steering box requires the shorter column. get the column out of the truck you took the steerign boxes out of.
