Still cant figure out brake lines on disc conversion
Texas69
Post by Texas69 »
Could someone please send pics of a completed dis conversion (F100) showing brake lines connected to the calipers (left and right side) and to the frame? I looked over tech swap pics but they do not show brakes installed.
Thanks for ever bodies help.
1969 F100 Ranger shortbed 360 3 on tree.
floyd67
Re: Still cant figure out brake lines on disc conversion
Post by floyd67 »
i just ran my lines to the prop valve the same way they were on the '79 that i took the front end off of hope this helps
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
19FORD67
Post by 19FORD67 »
This is a pic of the disc brakes on my donor truck, hope it helps.
:fr:
'92 Mercury Cougar
AK F100
Post by AK F100 »
I believe the passenger side goes from the frame, across the front crossmember and to the proportioning valve/distribution block or master cylinder.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
the only disc brake swap mods to the brakes lines that are neede to ad are the brackets for the rubber hoses to reach the disc brake calipers properly. other than the proportioning valve lines need to be bent into place that should be all you need to do. that picture that is posted shows the brackets with hte rubber line hooked through it.
