not sure whats going on!
shaggys_bump
Post by shaggys_bump »
I am having problems with my front-end, while driving down the road it is really squirrley and not very stable (i have to work to keep it on the road). when i go in corners is the only time i dont have to constantly correct the steering. i am running 295/50/r15's (WIDE TIRE) all the way around. i also have a set of 8" wide stock height tires in the shed, but no matter what tire i run it still has the wreckless steering. it almost seems better with the 295's on it. any suggestions, it would be greatly appreciated. i cannot drive the truck right now its too hard to control.
1970 F100 Ranger XLT SWB 302
2004 Nissan Murano
1998 Isuzu Amigo "v6 4x4 conversion comin soon"
kaptnkaos
Re: not sure whats going on!
Post by kaptnkaos »
Hey shaggys_bump
I have heard that bumps don't handle real good with wide tires with out front and rear stablizers.
I'm running 285/35 /16's on my '68 F250 and don't have any problems.
You might want to have the front end checked out real good.. could be about any thing
KaptnKA 8) S
57fordf100
Post by 57fordf100 »
have you looked at the king pins and made sure everything is nice n tight and that nothings loose
FORD IS LIFE OIL N GAS IS MY BLOOD
shaggys_bump
No i havent checked anything yet, been waiting on some money so i can get my dreambeams and replace everything under there. i would like to take it to someone to have a look at it but i was hoping it would have been an issue i could fix myself. Im also just not to fond of someone else having thier hands on my baby.
2004 Nissan Murano
Georgia71
Post by Georgia71 »
I think king pins also.
georgia71
get rid o fthe wide front tires and check the kingpins.
shaggys_bump
but if the wide fronts are the problem then why does it still do it when i put the narrow tires on
2004 Nissan Murano
70shortwide
Post by 70shortwide »
my guess is alignment. if its set without enough tow-in it will drive all over the place like your describing. another possibility is that they tightened the steering box too tight so theres no slack, you want just a little so that slight movements with the steering wheel dont run you in the ditch, or into traffic
shaggys_bump
ok well i guess this is my solution, i have a set of atlas 15-10" wheels with brand new tires for trade for a set of atlas 15-8" anybody got some? sorry i told yall wrong the tires on front are 265/50/r15 almost as wide as the 295's. but also a little shorter. and hopefully an alignment job soon.
2004 Nissan Murano
