Slight problem with drum
1970f100x
Post by 1970f100x »
Ok, so I took off my wheel today, and I went to pull the drum off, and its stuck. So I banged on it, then I torched it, and nothing. It feels as if its almost welded right onto axle. Btw, it is the driver rear. Any suggestions?
cep62
Re: Slight problem with drum
Post by cep62 »
More heating and more beating.
Try spraying some penetrant in the stud holes.
I've seen someone use a big puller.
I also had one I couldn't save and had to cut and break it up.
QC
Post by QC »
I have gotten them off by useing 2 pry bars opposite of each other to put pressure on the drum and then tapping on the end of the axle with a big hammer. This is easier if you have help. You don't want to hit it so hard you beat up the end of the axle. Hitting lightly with a big hammer seems to work better than hitting hard with a small hammer.
69 F-100 Ranger 302
oldschoolrods
Post by oldschoolrods »
my f250 had screws in the rear holding the drum on....took me a while to figure that out :doh:
lee_ford
Post by lee_ford »
oldschoolrods wrote:my f250 had screws in the rear holding the drum on....took me a while to figure that out :doh:
I never heard of that. Good info... Thanks.
My 1969 F100 Gallery
[Please note: A lot of what I write may be common knowledge to some of us. But for a new comer and even us at one time, somebody had to inform us that FIRST time.]
