oil pan removal question
in my 69 f100 360fe...i have the motor torn down to the block...just did my timing chain...while im waiting for my heads and before i put a new oil pan gasket on for the timing chain cover, i was wondering if the oilpan will clear everything and come completly outta the truck...if so i would like to go ahead and do a high volume oil pump...is this possible with the block still in the truck and without having to unbolt the motor mounts or anything?? just drop the pan and oilpump???
- 71PA_Highboy
Re: oil pan removal question
Just replace it with a Standard volume pump. The HV doesn't gain you anything in an FE other than lakes of oil in your valve covers. Pump is less expensive too.
Saves $$$ too on valve cover gaskets when you replace them because they leak with all the extra oil up there ...
JMHO,
eric
JMHO,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
cool cool...ill do that then...but my main question is if i can remove the oil pan and pump with any problems with the block still in the truck?
- ezernut9mm
it can be done, but you have to drop the pan, and then drop the pump into the pan to remove. you might have to turn the crank to clear all the rod caps as you pull it out. you might also have to unbolt the engine mounts and jack the engine up for clearance. i just did this, but i was removing a rear sump pan-which is deeper-to install a front mount pan. it was a pain, but was doable.
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/68%20f100/HPIM1496-1.jpg)
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/70%20f100/HPIM2004-1.jpg)
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/67%20f250/HPIM2562-2.jpg)
if it has the heads off and you pull the pan you are only 8 rings and main and rod bearing away from a infrme rebuild on it.
