rack and pinion swap?
- tybob81
I have been thinking about doing a rack and pinion swap for a while. Any thoughts or concerns? I want to do this for driver side header clearance with my 351w. I have a rear mount on the crossmember manual rack I want to fab up and try out. Feedback would be nice.
- marz68
Re: rack and pinion swap?
you will have to get a center steer rack for this to work.
You may have a problem finding one that will have the correct angle
to meet up with your stock column.
I think this is doable with some fab work to bad I don't have a stock truck to try this on.
If you do do it keep me posted.
