9 inch rear end brakes
Well since she didnt get a decent bite on the sale I guess its time to do the job that she needs. The back brake on my 67 of the right side got so hot they started smoking. I have no idea why other than something got lodged inside of the drum but either way I was going to change both of them anyway. Now the big question what years and models can I use as a replacement for this truck? Im sure it is bone stock and it is a 9in 5 lug with 3.50 gears. Bill
Proud owner of a '67 F100. 390 cid, Edelbrock performer, Holley 650 vs, hooker headers and a Crane cam. B&M built C-6 and 350 gears in the rear end.
Re: 9 inch rear end brakes
i think with out looking that the brakes on a 67 are narrower. so the drums have to match the shoes in width. if you go with a different year drums or shoes you need to match them also to the same width.
I just got back from the local Pick and Pull. I got what looks to be the same drum off of a 78. Im going to pull the wheel and see if its the same. TY. Ill be in touch if its the same. Bill
Much to wide!!! I saw one that was alot closer but it was on a 56 and it only had one "Rib" instead of 2. Im not sure how to describe rib but Im not much of a mechanic. Billfordman wrote:its probably too wide of a drum.
Auto Zone has them for almost 50 bucks, they are 11x 1 3/4
'92 Mercury Cougar
