Will F100 rotors fit F250 Spindles?
I have access to a 79 F250 donor truck which has power discs, stabilizer bar etc. If I use the whole setup including the i-beams from the F250, would 79 F100 rotors fit the F250 spindles? Is there a difference in the spindle shaft size or bearings used? Thanks for any info on this. I'd like to know if this works before I buy it....
