On Overhaulin
On Overhaulin
I just saw a '65 get overhauled on TV and I noticed that Chip mounted the MC and booster on the frame under the cab, how is this possible and how do you put fluid in it?
'92 Mercury Cougar
Re: On Overhaulin
it would look similar to this....
And there usually is an access panel to add fluid
Re: On Overhaulin
I was unaware that the MC resevoir has to sit higher than the pistons unless you use a residual valve, thanks. How do the brakes actually apply pressure? Some kind of fancy shmancy brake lever that is Chip Foose?
'92 Mercury Cougar
- seattle67
Re: On Overhaulin
I installed one of these on a streetrod I built a few years back.
To fill your reservoir, you either need an access plate in the floor or, like I did, put in a remote reservoir kit.
Dan
Re: On Overhaulin
Looks pretty sharp, how do you keep from over filling? What about seeing the level?
'92 Mercury Cougar
Re: On Overhaulin
you would see the level in the filler neck thing. just don't over fill that.
Re: On Overhaulin
Ah. Wasnt sure if there was fluid in there, it all makes perfect sense now
I'm a little lost on how to get my brake pedal to the end of that bracket I'll bet that would be a fairly simple answer also, I like the idea of cleaning up the engine compartment and making more room. Maybe this mod is in my future, would be nice,...
'92 Mercury Cougar
- seattle67
Re: On Overhaulin
Yup, it cleaned up the engine compartment for sure. When I bought this car the previous owner had mounted a booster and master cylinder on the fire wall, I just couldn't live with that.19FORD67 wrote:I like the idea of cleaning up the engine compartment and making more room. Maybe this mod is in my future, would be nice,...
Dan
Re: On Overhaulin
'92 Mercury Cougar
- seattle67
Re: On Overhaulin
A 1936 Chevy that was a casualty of a divorce. Damn, I miss that car.....19FORD67 wrote:What is that?
Dan
