should be "breaks" instead of "brakes"
skam
Post by skam »
they are busted.
mine KINDA worked a little, and then I replaced my carb. the line from the Brake Booster runs to my intake manifold (I have a 351c) and now it doesn't stop for ****. I can have the Pedal mashed to the floor and still back out of my slanted driveway when in gear...... any ideas? I have an aftermarket Disc setup for the front (which they say bolts right up to my stock system, no need to change booster/master cylinder) but I cant' even drive this thing to go have it put on.
any ideas?
Drive-in banks were established so most of the cars today could see their real owners.
rogerlc
Re: should be "breaks" instead of "brakes"
Post by rogerlc »
Hey man new to this site need a liitle info on your brakes. Getting your booster vaccum from intake is cool should have plenty of it unless there is a leak in the intake and did u put on a proportioning valve that changed your front to rear ratio. you did convert to front disc?
skam
Post by skam »
haven't put the disc-setup on......yet. but not sure i'm gonna if they aren't gonna work, due to another problem.
well it could be that the engine is running better now and pulling more vacuum. so the booster is working better. so the brakes now work worse because they are easier to push.. i would redo your brakes or go ahead with the disc setup. if the booster was bad you would have a bad vacuum leak and the enigne would run bad because of the big vacuum leak.
skam
Post by skam »
my brakes don't work at all. the engine does run better though.
if it isn't what i posted before mayeb the vacuum line has a leak now. or the lines just rusted through or something similar. just by coincidence (sp). it just happened at the same time by accident. check them out. i really don't think the carb had anything to do with it. unless you bumped something and didn't relize it.
skam
Post by skam »
thanks, I'll check the whole system out.
Wes
Post by Wes »
what does the pedal feel like, does the travel stop well above the floor board, firm hard pedal ? Does go to the floor, and feel like stepping on plum ? You show be able to keep the truck from rolling down your drive way w/ or w/o a working booster. I think you had better look at your brakes Hydraulic system.
If you find you have a bad master cylinder, I would go forward w/ the disc swap, you will need a master cylinder for a disc/drum system.
Wes
67 F250 High boy
69 Bronco
skam
Post by skam »
firm/hard pedal, but very little braking, any leads where I could get a master cylinder for disc/drum? looked on ebay but most of the sellers I've contacted.......weren't sureif it would work for me.
tommycaire@yahoo.com
Post by tommycaire@yahoo.com »
over the weekend i installed a 1975 vaccum brake booster on my 1972 f100 pickup. everything fit well except the length of the rod on the brake booster. i had to make one a little bit longer. i have brakes yhat will hurl you through yhe windshield.
Wes
Post by Wes »
If you have a good firm pedal my next suspicion would be drum condition and lining. Hard glazed linings and hardened blue drums requires tremendous pedal effort. Also look at the shoe adjustment.
Wes
67 F250 High boy
69 Bronco
skam
Post by skam »
well I started putting the parts on tonight.......and NOTHING is right. the rotor doesn't fit the spindle right, the directions suck, the outside wheel bearing doesn't go far enough on the spindle......I think they got mixed up. or they just suck. anyone know of a rotor that bolts on and uses the stock wheel bearings?
i think 73 and 74 are direct bolt on rotors and bearings.
skam
Post by skam »
thank you.
skam
Post by skam »
finally got it all on..... needed different wheel bearings, and the rotors i had they drilled 5x5 bolt pattern, they machined me a new pair and now she'll stop! yay.
