Doing Away with Power Brakes
1969_Fords_Forever
Post by 1969_Fords_Forever »
Hey guys, I was wondering what it would do to convert my 1969 f100 from power brakes to non power brakes. They are to stock drums all the way around with no aftermarket modifications. Are the wheel cylinders different sizes for power brakes and non power brakes? I should note that there is nothing wrong mecanically with my brakes, just a small vaccuum leak I just perfer the more firm feel of the pedal with the non power setup. Any suggestions would be helpful. Thanks
FLATBEDFORD
Re: Doing Away with Power Brakes
Post by FLATBEDFORD »
On a related note, I am considering converting my 360 to hand crank starting and doing away with the electric starter motor.
Steve
My Photo Gallery
mr_josh
Post by mr_josh »
FLATBEDFORD wrote:On a related note, I am considering converting my 360 to hand crank starting and doing away with the electric starter motor.
Okay, now I have to clean coffee off of my monitor... :lol:
Josh
'72 F-100 Sport Custom 4x4
just unpplug the vacuum hose to the brake booster and you are done. don't forget to plug the manifold vacuum hole tha the hose came off of.
BRUTUS_T_HOG
Post by BRUTUS_T_HOG »
i would take power brakes ANY day. do you know how much it sucks to hold the brakes on an incline at a red light?
ASE Certified Technician
seattle67
Post by seattle67 »
It would be an easy swap to take off the booster, just unbolt the master cylinder from the booster and let it lay forward, being careful not to damage the brake lines. Unbolt the push rod from the brake pedal, unbolt the booster and brackets from the firewall, remove it, and then bolt the master cylinder directly back up to the firewall. The only thing you will need is a new push rod that goes from the brake pedal to the master cylinder, a junk yard item. No other parts will need to be changed out.
Dan
flyboy71
Post by flyboy71 »
I may just leave my floorboards out and use my feet. :lol:
-Jeff
19674x4
Post by 19674x4 »
BRUTUS_T_HOG wrote:i would take power brakes ANY day. do you know how much it sucks to hold the brakes on an incline at a red light?
it aint that bad. even when you got 2 yards of rock in the back
My Photo Album
flyboy71 wrote:I may just leave my floorboards out and use my feet. :lol:
have you tried the new predrilled and slotted brake lines yet? :lol:
BRUTUS_T_HOG
yeah sure its managable, but it catches me off guard when i start rolling backward after i've been driving my little ranger for a while or the 350 bump
ezernut9mm
Post by ezernut9mm »
not to be condescending, but why? are you wanting to clean up the look of the under hood area?
scott123
Post by scott123 »
Straight answer, I woudnt do it.
On a side note, where can you get a stock bump crank handle. LMC doesnt sell em.
1972 Camper Special
5.0 EFI TFV-IV Ignition Auto O/D
crank handle? for the window? if its for brakes what is a crank handle for the brakes?
taylor351
Post by taylor351 »
I think the crank is for the 360.
Thanks guys I needed a good belly laugh. :lol: :lol: :lol:
To original poster:
Just remove your booster, plug the vac tube you might have to mess with the length of the brake lines, yet they might stretch far enough to fit.
Keith
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
Redcap
Post by Redcap »
Why?
