brAKEs
brAKEs
Just replaced all 4 drums and pads on my 67. After bleeding them 3 work just fine but front passanger side is being stubborn and wont brake. It gave 1 good shot of fluid when I first bleed it then nothing after that just litte bit of fluid came out after with no pressure. Any ideas before I take brake hose off tomorrow?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
- BRUTUS_T_HOG
Re: brAKEs
take the bleeder out and clean it. it has a blockage in it. or in the brake line leading to that wheel.
Re: brAKEs
Collapsed line maybe??
- FreakysFords
Re: brAKEs
Same thought. I'd check the hose first and make sure the lining hadn't swelled shut. Or in truth, I hardly ever check them any more. I just replace them.
- michael69
Re: brAKEs
I had the same problem once and the wheel cylinder itself had a clog in it that would not let the fluid though.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
- thebannister8
Re: brAKEs
i'd remove the bleeder first aswell...protect your pads from the fluid though
