off topic question- toyota
Hey guys is anyone on here familiar with toyotas at all? My son has a 91 toyota truck with a v6 3.0 . It's making a knocking noise as if a lifter or valve has gone bad. I also ran a compression test and 4 of the cylinders had 135 lbs and 2 had 95 lbs. The weird thing is the 2 cylinders that read 95 are at opposite corners of the motor. Is there any tests I can do to confirm a bad lifter or valve? I also noticed white smoke coming out of the tailpipe. Any help is GREATLY appreciated.
Troy
- Dragon
Re: off topic question- toyota
White smoke in tailpipe cracked head or bad head gasket. 135 to 95 compression is outside of limits and 101 should be the lowest. Worse problems than the noise. Are you sure it is pushrod motor? What is the engine designation off the Tag or the Valve cover like 22R 30R 2TC and so on.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.
My Gallery
Spark test
My Gallery
Spark test
- heep70
The 3.0 I here are junk.
Goto the forums in http://board.marlincrawler.com/ or Ask a dude named Crash on http://www.nw-wheelers.com/forum/index.php.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Thanks dragon and heep70. That was what I was thinking but thought I would get someone elses opinion. I took a look and could not find anything on the valve covers and the sticker on the hood was not much help. I don't even know where to find out if this is a pushrod motor. My son is going to check on some sites he goes to. I'm more of a backyard mechanic, I can do the older motors like in the bumps but don't know about this one. Are they hard to tear down? Thanks again for the input
Troy
- Dragon
It is an overhead cam motor and uses two different types of cam followers. A rocker type or a cup type.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- DuckRyder
I know a guy who has bought 2 4-runners with bad 3.0s, and put junk yard motors in both of them and sold them at a profit, even after paying 1200-1500 for the motor.
Sounds like a pattern to me...
Thanks for the help guys. Toyotas are not my thing. My son has read that the 3.4 bolts up the same and is a better motor. I guess there is some wiring changes to do though. God I love our bumps. At least there is room to work in there in our trucks.
Troy
- 390F100
The 3.0 i believe is the older version of the 3.4, yes the 3.4 is darn near bullet proof and is a great powerplant. the 3.o engine code is a 3vz-e I believe but dont quote me on that, and dang near every toyota engine is great but it's all in how it has been taken care of. My 5sfe engine in my 01 camry looks brand new internally with 190k on it, but I have done exceptional maintenance on it too. In my opinion, if the 3.0 is knocking and blowing white smoke and the 3.4 is a "direct swap" do it!!! As you can see i'm a fan of toyota it's all I own other than my bikes..
390
390
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- TheMadScientist
3.0 3vz engines are famous for head gaskets going bad. Probably got antifreeze in the oil pan and washed out the bearings, causing the knocking sound. I have a pile of those 3.0s that all knock that I've replaced out of other peoples toyotas. If you ask me the 3.4L 5vz is a way better engine and will bolt into your truck if you use the 3vz motor mounts. And a litle bit of electrical wiring. I'm known as the toyota god around here and have owned about a hundred different trucks and 4runners.
2006 F-350 Crew Cab Lariat 4X4 6.0l Diesel Tow Rig
2005 Excursion Limited 4X4 6.0l Tow Rig
1977 F-350 Crew Cab SWB (4x4 soon)
1972 F-350 Crew Cab 4x4 SWB Cummins 12V, NV4500, NP205, HP60,D70B, on 35's
1966 F-250 Crew Cab (4x4 soon)
1965 F-100 SWB 351C 4v
1956 F-100 2wd SWB 429
1972 Bronco Explorer Sport
1969 Mustang Fastback (tubbed and caged, soon to get a 429)
1967 Mustang Fastback 427W, C6
1965 Mustang Fastback 347 FI HO, T5
- Lar4t9r
I have a 1988 4runner, owned since new and it has 200,000 miles on the clock. The 3vze engine blew a head gasket in 1996, had to have the engine rebuilt. Didn't think about a recall at the time and my mechanic didn't mention it either. Several months after the rebuild, found out about factory recall for the head gaskets, but they wouldn't reimburse me. Said I should have brought to the dealer. My point is, except for the head gasket, it's been a good engine, but I don't beat the crap out of it.
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
- willowbilly3
All of those V6s were back multiuple times on recalls for heads/head gaskets. You might want to check with you local dealer and see if yours is eligible still. Might be too late. Toyota also has campaigns which are like a recall except they don't notify anyone, they just do the fix if it comes in.
Have your vin ready and call them, might be worth the effort.
