Dual front shocks, which shocks to use ?
MadMaxetc
Re: Dual front shocks, which shocks to use ?
Post by MadMaxetc »
Just run 2 of the blue (low end) monroes.
I have the brackets for the I-beams for sale.
Dan
FORD Girl
Photobucket Pictures
dan post a pic of those would you. i have never seen those.
Frogger
Post by Frogger »
MadMaxetc wrote:Just run 2 of the blue (low end) monroes.
I would be interested in a set of those brackets and the info on installing the 2 extra shocks!
mad2smile
Post by mad2smile »
im interested as well. i think two shocks on my F-150 could really improve its behavior under load (which is most of the time because i do construction).
1976 Ford F-150 Supercab 4x2 w/390FE engine C6 - 76,000 miles
1995 Taurus SHO 3.0L Yamaha V6 MTX w/Quaife LSD - 75,000 miles
2002 Dodge Neon R/T 2.0L I4 MTX - 91,000 miles
1993 Dodge Ram 3500 5.9L Cummins 6x4 Flatbed MTX- 100,000 miles *SOLD*
Alvin in AZ
Post by Alvin in AZ »
Yeah, good shocks like Rancho 5000's or doubled up regular shocks are cool. :)
BTDT :)
...but they ain't a replacement for stiff springs! :)
Do you know it?
Question. :/
We talkin about a 2wd or 4wd here? :/
Alvin in AZ
Redcap
Post by Redcap »
Why two more shocks? Sounds like you have other issues going on if you think this will fix something.
Alvin in AZ
Redcap wrote: Why two more shocks?
Weird sounding to ya, huh? ;)
Back in the "old days" it wasn't uncommon. :)
For me it was dual shocks all around because my pickup
would dance sideways on dirt roads without 'em! :/
Original wimpy springs or my new "lumber wagon springs"
both were the same. :/
It was just something Ford Twin-I-beams do. The 2wd
Ford "company trucks" did the same. 2wd Chevys didn't. :/
The 4wd company trucks weren't on districts/areas that
had straight stretches of high speed dirt roads, so never
learned how 4wd's handled 'em. {shrug}
Alvin in AZ
mad2smile
Post by mad2smile »
is there a store where brackets for twin I-beam trucks can be purchased? or would i have to make them?
i have never seen the bottom brackets but i bet you could get some from a dentsdie and flip sides withhtem and they would bolt in tandem with your other shocks. buti am guessing. as far as the tops. i ahve seen some frames that don't have the dual shock holes and some that do. drill them out wouldn't be the big of a deal if you had the right drill bit.
