Im running a disc/drum setup and I'm trying to understand which brake line goes where, off the master. Does the line in the front of the master go the front calipers and the rear line goes to the rear brakes or is it reversed? The rear fitting is slightly larger than the front, which I think goes to the rear, but I'm not positive. I have a prop valve that I will use also. That part I am clear on. Thanks for the help.
Mike
