swap
big dog
swap
Post by big dog »
I have a 1978 ford bronco and would like to put a bumpside body on it. I think the frame is a shortbox and was wondering if the bump side would fit as long as it is a shortbox also. I have been reading out the differances in the old frames vs the newer frames and does not sound to bad to do but still have a couple of questions. First one is will the brake booster on the 78 bronco fit on the 67-72 cab? The second question is will the steering coulum on the 67-72 fit the steering box on the 4x4 bronco frame? I like the idea of 4x4, disc brakes ,and powe steering and gas tank out of the cab. I have 2 1969 short boxes one low rider with a 429 and one with a straight six and would love to have a 4x4 to my collection. Thanks in advance. :D :D :D
Re: swap
big dog wrote:I have a 1978 ford bronco and would like to put a bumpside body on it. I think the frame is a shortbox and was wondering if the bump side would fit as long as it is a shortbox also. I have been reading out the differances in the old frames vs the newer frames and does not sound to bad to do but still have a couple of questions. First one is will the brake booster on the 78 bronco fit on the 67-72 cab? The second question is will the steering coulum on the 67-72 fit the steering box on the 4x4 bronco frame? I like the idea of 4x4, disc brakes ,and powe steering and gas tank out of the cab. I have 2 1969 short boxes one low rider with a 429 and one with a straight six and would love to have a 4x4 to my collection. Thanks in advance. :D :D :D
i haven't read of anyone tring this yet. i think i would check the broncos wheel base and total frame lenght and then check the bumpside the same way. that will tell you if it will even work at all. the booster will bolt to the firewall. your bake pedal connection is what you have to worry about. if tis aq flat bar its ok to redrill the bar to make the pedal line up with the booster. the 2wd and 4wd columns are different. plus they 4wd uses extension arms to reach the 4wd box. and so does the bronco.
Hawkrod
Re: swap
Post by Hawkrod »
The Bronco wheelbase is 104, the shortbed is 115. You would have to chop the bed in front of the wheels or lengthen the frame to make it fit. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
LANCE65
Re: swap
Post by LANCE65 »
I think that would be really COOL. Build a flat bed for it and go wheelin!
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
