cam?
hotrod ford
cam?
Post by hotrod ford »
for our engines (fe), what is a to big of a cam? :hmm: if you have an eng bored 10-30 over, an aluminum intake and a nice carb. maybe even some heads, what is the perfect cam?
averagef250
Re: cam?
Post by averagef250 »
The *perfect* cam for an FE is two cams with the SOHC or Cammer.
To find your perfect cam it completely depends on what your doing. Fun power is built with matching parts. FE's have an almost infinite number of differing factory and aftermarket parts you could match up.
427
Re: cam?
Post by 427 »
Need more info like auto or stick? rear end gear? And how you plan to drive it?
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
FORD428CJ
Re: cam?
Post by FORD428CJ »
What sizes engine? Heads? Valve size? Intake? Carb? what rig? what gears? Is this all Drag, Street or both? what do you want it to do? Need info here. Whats too big for one guy my not before others!?
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
convincor
Re: cam?
Post by convincor »
if your not dial-up, go here and download the compcam software. fill in what you got and you'll get recomendations.
http://www.compcams.com/camquest/default.asp
that said, I'm looking at the XE262H for mine. similar set up running early tall port heads.
"Still Plays With Trucks"
hotrod ford
Re: cam?
427 wrote:Need more info like auto or stick? rear end gear? And how you plan to drive it?
360/c6, 3:00 or (3:73) rear gears, valves and heads are stock. will add a 670 holley and edel. performer intake. truck has headers already. swb f100
427
Re: cam?
Post by 427 »
Hot Rod Ford this is my opinion. I would recomend the Comp Cams 270 high energy or if you change the converter I would use the 280 magnum. I personally run the comp magnum in a 294 grind its a solid lift cam and your 360 is hydraulic. I also run a 4spd. But your on the right track with your add ons. It should run very good with the extra performance and 3:73 gear. Hope this helps,Brian.
95 Ford Lightning
38 John Deere G
fitzwell
Re: cam?
Post by fitzwell »
too much carb, no flowing heads. Stick with a basic "rv" grind. Most cam companies don't understand the flow characteristics(sp?) of the FE, let alone the various combinations. For what you have , possibly a "262 "series from comp. If you can call the cam tech line from whatever maunfacturer, and get one of the old dogs...so much the better.Be realistic when you talk to them, and the more info on your combination, the better.
as always... :2cents:
hotrod ford
Re: cam?
427 wrote:Hot Rod Ford this is my opinion. I would recomend the Comp Cams 270 high energy or if you change the converter I would use the 280 magnum. I personally run the comp magnum in a 294 grind its a solid lift cam and your 360 is hydraulic. I also run a 4spd. But your on the right track with your add ons. It should run very good with the extra performance and 3:73 gear. Hope this helps,Brian.
what would you recommend for a converter change? or would i really need to?
427
Re: cam?
Post by 427 »
Hot Rod Ford it would depend on which cam you choose? If you get a rough lopey cam you definetly need a stall converter. The good is you get better take offs because of the higher r.p.m. before it locks up,the down side is these babies make an engine suck a lot of fuel faster. I would stay more with the 270 duration series of cam for better drivability. If you did get a converter I think a 2,000 stall would be plenty imo. I used to have a 351 Clevland in my 68 and it had a 280 cam in it and the factory stall and I had to put in in neutral at red lights or it would load up and die. Hope this helps you.Brian.
95 Ford Lightning
38 John Deere G
FORD428CJ
Re: cam?
Post by FORD428CJ »
If it was me...... I would call Ken @ Oregon Cam Grinders and tell him what you have, what you are trying to do. He will punch out a killer shaft for your FE. Ken has ran FE's for years and has a very good understanding of them, when most cam companies do not! I never cared for off the shelf cams myself.
By the way. Kens prices are VERY reasonable and you will be VERY happy with it. JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
hotrod ford
Re: cam?
sounds good, thanks guys :thup:
Re: cam?
This is about like asking "what’s the perfect girl", which is to say it is impossible to answer and any answer you may get is likely to be opinion and conjecture. :P
That said, Crane 343801 (343802 for a kit) is my opinion based on the information provided.
