Hey guys question? I was wondering if a 16" rim would fit on my 79' 4x4 f-250? It has the dana 44 hp in the front, 60 in rear. Because tires are getting a little scarce for the 16.5" this might be an option to keep the stock hubcaps I want to use.
16" rim on 79' 4x4 f-250
Re: 16" rim on 79' 4x4 f-250
im sure it will fit. put the correct size tires back on it to get the speedo correct. or change the speedo gear in the transmission.
- averagef250
Depends on the wheel. Early 16" alloys usually will not fit, late model ones will. 16" steel wheels should fit fine.
Cool thanks guys
