3"-5" drop on a 69'
tpstang86
3"-5" drop on a 69'
Post by tpstang86 »
everywhere i look all i can find is a 3-5 drop with the i beams(dream beams) from djm, i know there has to be other options, where do you look, i want to slam the truck as far as possible without air bags and with out destroying the driving. anyone have any pics of one with a 3-5 drop or any info on options thanks
tpstang86
re: 3"-5" drop on a 69'
Post by tpstang86 »
td- i have seen your truck on your sig with the posts you have made, i really like the set up you have, i would love to see some more pics and get an idea of what all it took to get urs where it is, there are a ton of posts on here to sift through, so i may be asking something you already have posted, thanks and talk to ya soon
td
Re: 3"-5" drop on a 69'
Post by td »
3'' djm dreambeams with 1 coil cut out.
flipped front leafspring hanger in the rear and removed 1 leaf.
8 degree's of shim added to the rear to correct pinion angel.
td
Post by td »
Calvin Gunter
Post by Calvin Gunter »
tp, It's easy to get the 4 or 5 inch drop in the rear with the hanger flip.The challenge is the front,the beams give you 3 inches but when I cut my coils I got the negative camber I didn't like.So I ended up with stock coils and the I beams and a half flip in the rear.Keep us posted,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
