I-Beam Pivot bushings
Anybody changed these out? Any tips?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
re: I-Beam Pivot bushings
Did this job tonight. It was a learning experience for sure. Made the truck drive like new.
1989 Ford F150
1989 Ford F150
- robroy
Hi Mjhaltom,
I'm doing this to my truck currently also. I'm curious to hear more about what you noticed before and after installing the new bushings. What driving characteristics had improved?
Did you go for stock or performance bushings?
Any trouble tapping out the old ones? How about pressing in the new ones?
Thanks!
-Robroy
Thanks!
-Robroy
Before the swap, the truck would lurch hard to the right when entering a gentle right curve. This fixed that problem.
Drill out the rubber and collapse the metal outer sleeve in on itself with an air chisel so that it will pop out.
Coat the bushing with anti-seize lube and use washers and the original bolt and nut and a short piece of pipe (I used a cut down 2" PVC pipe fitting) on the back side to press the bushing in with the impact driver. Sandwich these items together. The large washer then the pipe ont he back side and another washer and the nut on the front. I found it impossible to hammer the bushing in with the beams still on the truck because you cant get a solid lick with the hammer.
Hope this helps.
Hope this helps.
1989 Ford F150
1989 Ford F150
- robroy
