Tried to start the trucks new 390 today, but am not getting any fuel up to the carb. I have a see thru filter and I got a tiny little bit in it, but nada in the lines. I tried taking it off the tank and dropping it directly in the gas can, still nothing.
I reused the fuel pump because it worked before, and it still looked good. It does not have the filter on the bottom, its a different type, so it cant be plugged.
Anybody have some tricks for testing this thing, before I look at getting a new one? Thanks!
No pull from the fuel pump.
re: No pull from the fuel pump.
You pretty much got it. Take the outlet off put it into a canister and if you don't get anything out fuel pump is shot. I like the added part of putting the suction line into a gas can to rule out an air leak.
- Dragon
Remove the tank hose under the truck and see if fuel runs down. Ford pumps don't suck they push. Gravity feeds the pump. It is like stealing gas. You suck and then the lower position of the hose end keeps the flow going.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.
My Gallery
Spark test
My Gallery
Spark test
