87 merc grand marquise
390F100
Post by 390F100 »
I landed an 87 merc gand marquise for free with an excellent running drivetrain it ha a 302 in it. I know people have been swapping out front clips off the 06 model, my ? is it about the same process for this year marquise? for the rack and the entire front suspension going into a 68 f100 with a 390?
td
re: 87 merc grand marquise
Post by td »
From what ive read the pre 03 models are all weld in cross members so it would add alot of fab work to the swap. not that i even know if the pre 03 front ends will go under our trucks.
carcrafter22
Post by carcrafter22 »
td is right pre 03 is welded to the frame. You can adapt that front end to your existing frame if you want but its a little work, more than most will want to do. If your good with your hands it wont be that bad though.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
Banjo
Post by Banjo »
Are these year model Marquis and full size FOMOCOs perimeter frames that run close to bottom of door, or is frame further toward center of body?
