Rear Shocks - Correct P/N?
70F250CamperSpecial
Post by 70F250CamperSpecial »
I am trying to get a set of Monroe Gas Magnums for the rear my 1970 F250 Camper Special. The shock that the parts store shows/gets for this truck does not have a stud on the top.; P/N 34958. Has anyone run across this, and if so do you have a P/N for the shock that will fit.
Thanks, Rob.
1971ford
Post by 1971ford »
i just noticed my 71 f250 has the stupid stud top rear shock action. now i have to replace the mounts...
anyone know why ford did this to some of the bumps?
-Ryan
convincor
re: Rear Shocks - Correct P/N?
Post by convincor »
looks like the application that has the stud type top mount is the standard duty. #59562 But they don't make it in a "Magnum"
http://www.partsamerica.com/productdeta ... 50&PTSet=A
Heavy duty, crews and CS use. #34958 http://www.partsamerica.com/productdeta ... 50&PTSet=A
"Still Plays With Trucks"
1971ford
Post by 1971ford »
thanks!
perhaps its because my f250 is the lightest duty f250 you could get...
but i want the big boy ones so im going to have to find some new mounts so i can run some temporary Rancho's :thup:
unless Rancho (or a similiar company) has stud mount shocks. couldnt find any on there site though
-Ryan
convincor
Post by convincor »
I've got a set of mounts that came off the 70 F250 HiBoy I stripped.
May bolt right on. :dk: I'll take a look tomorrow..
1971ford
Post by 1971ford »
please do! :thup:
-Ryan
mrtleavitt
Post by mrtleavitt »
Up to '69 all F-series Fords had the eye top rear shock. From 70-72 they had the stud top. They can be converted very easily to which ever one you want.
1971ford
Re: re: Rear Shocks - Correct P/N?
Post by 1971ford »
mrtleavitt wrote:Up to '69 all F-series Fords had the eye top rear shock. From 70-72 they had the stud top. They can be converted very easily to which ever one you want.
thanks for the info! :fr:
-Ryan
convincor
Post by convincor »
My 72 CS has eye's on top.
mrtleavitt
I double checked my figures with LMC and and Autozone and all Fords from 70-79 had an stud type rear shock. That's weird convincor's has an eye hole. Anyways, the books have been wrong before.
convincor
Post by convincor »
Look at the links in post #3. The second is said to be for CS and crew.
If you look up f100, the had the stud top.
