351w in a 68 f100 2wd with power steering
Anyone ever figure out what headers work with this setup? I need some long tube headers bad.
I've read you have to get multiple years and use the driver's side from 1, and the passenger side from the other.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- td
re: 351w in a 68 f100 2wd with power steering
so if i understand this correctly, your saying 302 long tubes wont have clearance on a 351win in the same truck?
Thats what everyone keeps telling me. And I dont want to waste money on a set of they wont fit.
- td
i suppose that it makes
because i have mabe 1/4'' or less between one of the tubes and the powersteering box, so with the extra width of the windsor i can see there being clearance issues. so nobody makes headers for this application
? surely someone on the forum is running a windsor with headers and power steering.
- michael69
I have a 351w with c6 in my 69. I tried different headers and never found any that didn't hit front cross member.I finally just put shorty headers on it. They are for 79-86 mustang 5.0
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
- ezernut9mm
a guy over on the nloc (national lightning owners club) was modifying mac long tubes to work on the 93 to 95 trucks. same basic frame/engine setup. i don't know who makes a plug and play set for the 351 w ps for our trucks though. i would think that since the 351 was never offered in these trucks finding a set to fit will be impossible without doing some modification to the primaries.
- binder56jd
call stans or sanderson--if it's available and works correctly one of those 2 mfgs will know
now serving #235
now serving #235
- tybob81
Long tube 302 headers wont clear the P.S box with a 351. I am running Patriot heads that need a big primary tube. Stock replacement shorty headers for a fox body fit but will choke the motor down. I can tell you that a fairlane with a 351w long tubes will not work cause I bought a set and they didn't clear anything! Your best bet is going to try to use a set of long tubes from a fox body with a 351w swap or a 80 and up f150 with a 351w. I am going to bite the bullet and have a guy over here build me a set out of stainless. If the motor is stock a set of ford explorer 5.0 manifolds work well, but they are shortys.
- ezernut9mm
- HayHauler
- theskytoucher
Re: 351w in a 68 f100 2wd with power steering
Header for a 302 will work but as stated before they dont fit correctly, the headers are supposed to drop below the cross member on a 302 but on a 351w they have to sit on top of the cross member, and they push n the cross member causing vibrations,it also make the collector point slightly upwards!! I am running headers in my 68 ford with a 351w with power steering. Another problem you might run into is if you are running the bendix style power steering the headers are even tighter, the saginaw box has a little more clearance!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- td
theskytoucher wrote:Header for a 302 will work but as stated before they dont fit correctly, the headers are supposed to drop below the cross member on a 302 but on a 351w they have to sit on top of the cross member, and they push n the cross member causing vibrations,it also make the collector point slightly upwards!! I am running headers in my 68 ford with a 351w with power steering. Another problem you might run into is if you are running the bendix style power steering the headers are even tighter, the saginaw box has a little more clearance!
they rest on top of the cross member on a 302 also, i am on my third set of longtubes on 302's in these trucks and they all set on top.
- theskytoucher
Oh i see!! I guess all i have seen have been underneath!!!
-Troy-
1976 Ford F-150 4x4
1976 Ford F-150 4x4
