3 speed column parts
- 67 ford f100s rule
i was wondering where the best place would be to get those washers that go on the end of the shift tube. the ones that move the arms that hook to the transmission.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
Re: 3 speed column parts
you might try LMC...here is the linky67 ford f100s rule wrote:i was wondering where the best place would be to get those washers that go on the end of the shift tube. the ones that move the arms that hook to the transmission.
http://www.lmctruck.com/ICATALOG/FB/full.aspx?Page=98
