help please, front spindles
unclejtl
Post by unclejtl »
Hello everyone,
Looking for a little help please. In my infinate wisdome I did not write down in what order my king pins came apart :doh: The only diagram I have is in the NPD catalog and it dosen't show what I need.
First off the machine shop cleaned off my markings ( right and left) which I don't believe matters because they are the same, although on the inner side one has a "J" stamped in it and the other has a "T" (i believe).
Now to the main problem. These little seals were on the spindals when I took everything apart, but I can't remember which side, top or bottom
Now there is a small spot where the bushing dosen't go "flush" and I believe they go here, but that would put them under the bearings and stop the grease from flowing to them.
The diagram I have dosen't show the seals at all. I know the bearings go under the axle and the shims go on top, but can someone clarify where the seals go? Are they to keep water out of the lower bushing? If so how does the bearing get grease?
thanks for your time.
jason
Jason
Calvin Gunter
re: help please, front spindles
Post by Calvin Gunter »
I'm wondering the same thing.I'm getting ready to install DJM beams so I'll try to see where the seal goes as I take it apart.Maybe Saturday before I start on the beams though but I'll still post.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
