D60 rear wheel seal surface
On my '72 Dana 60 rear axle is the seal surface on the spindle replaceable? Mine is bumpy, like someone replaced it and messed it up, it looks like it may be a pressed on collar maybe. I hope so or I have to chuck this axle
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
'72 crew 4x4
'07 KTM 450 xcw
- 71PA_Highboy
re: D60 rear wheel seal surface
you need to put a sleeve on it...
smooth the grooves a bit... cover the grooves with JBweld, them put on the sleeve while the JB weld is still gooey... you want it to fill in the grooves under the sleeve. Then wipe off the excess.
I went to a muffler shop and had them cut and stretch me a piece of exhaust pipe so that I could install the sleeve.... I covered the edge of the pipe so it wouldn't scratch the sleeve...
I don't have the pic here at work... I will try and find it at home tonight and upload it.
HTH,
Eric
Here are some of my notes:
Axle nut - B6Y-4252-A - http://store.uhaul.com/product_detail.aspx?id=2047
C7TZ-2A635 F & C7TZ-2A635 E - e brake cables -
D60 redi-sleeve - 99250
D44 redi-sleeve - 99248
Oil/grease seal (both) Timkin 4250
HTH,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- averagef250
I was thinking of the JB weld fix, glad to here it can work, thsose sleeves are pricy but what can you do, thanks guys
James
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
- 71PA_Highboy
here is how I did it....
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
So the pipe fits on the outside and pushes the flange, not the end?
I've done sleeves on rear mains for Cat engines and the tool pushes on the end. I guess you hust have to be carefull
James
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
- 71PA_Highboy
Yup... that is the same way the vendor supplied 'cup' does it. You are actually supposed to remove the flange, but I never saw the need to on this application... Harmonic balancers are a different story.
hth,
eric
hth,
eric
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
