which leaf to remove from the pack
1971ford
Post by 1971ford »
on my 71 f250 LWB desert project, we are swapping in a 429 this weekend. we dont have money for suspension yet, but were going to need to do some testing of this new powerfull engine on the track :wink:
id like to soften up the rear alittle just for the testing. until we get our Deaver racing leaf packs.
im going to replace the shocks in the rear with some Rancho's.
how many leaf's should i take from each pack? 1 or 2?
which ones?
some info that might help.
71 f250 with 429, flexomatic rear suspension, no weight on the rear (no more gas tank, no bumper, no tailgate, empty bed), LOTS of weight on the front (aluminum will come later on). track is just really bumpy and torn up, we go about 30-35 mph, no jumps or anything :D
-Ryan
1971ford
Post by 1971ford »
after looking at it , i think removing 2 would leave too few of leaf's left :dk:
-Ryan
oldschoolrods
re: which leaf to remove from the pack
Post by oldschoolrods »
Maybe someone else will chime in but I agree i think 2 would be too many. Be very careful when you take the springs apart. We usually used 2 big clamps to hold the springs together when taking the center bolt out then slowly released the pressure. Don't forget new U bolts and a shorter center bolt when back together. :thup:
mrtleavitt
Post by mrtleavitt »
I agree, 2 would be too many at once. Try just one and then do 2 if you want to. But I bet 1 would be just fine. The one to remove would be the short, stubby one on the bottom of the pack.
1971ford
Post by 1971ford »
thanks guys, maybe tomorrow ill have the short one out of both packs. got to buy some Rancho's too so i can get those in.
forgot about the u-bolts and center bolts.
looks like the u-bolts have enough thread for removing the thick bottom leaf still. well put in a new center bolt though.
-Ryan
You might be able to get away with removing the bottom leaf if you were just buzzing around town, but I'd definitely NOT recommend removing that one for what you're planning on doing with the truck. You're bound to break the rest of the leaves very quickly. Here's a picture of the remaining leaves in my choptop truck, after someone removed the lower overload spring. You can see how the other leaves aren't being supported and are starting to sag.
And this is just from sitting in a shop...it hadn't even seen any use yet!
1971ford
Post by 1971ford »
:eek: thats nasty stuff
what leaf do you suggest i pull then? if any? :?
is that truck misssing shocks and leaf clamps?
-Ryan
Your options are kinda limited. You need to keep the bottom overload leaf, plus the main leaf with the eyelets on each end, plus the two that have the riveted-on clamps (unless you decided to pick up some add-on clamps from the parts store). I'd say you might have one or two leaves that don't fit into any of those categories that could be deleted.
You know, something that just dawned on me is the fact that the F100 springs I pictured above from my choptop are quite a bit thinner than F250 springs...at least when compared to the F250 Camper Special setup. Here's a couple comparison pictures:
You can see how the F250 Camper Special leaves are substantially thicker than the F100 SWB springs...meaning you might just be able to get away with removing the lower overload leaf after all, if you wanted to give that a try. However, from your picture above it almost looks like your F250 has the same size and number of leaves as my F100s....so I don't know if I'd wanna chance it.
Yeah, I know...I'm not really a lotta help here, am I? :P
1971ford
Post by 1971ford »
yeah my truck is the lightest f250 you could get...
someone pick a leaf, any leaf lol
it will be better than my decision :D
actually i think ill chance it. because 1-im a risk taker lol 2-gives me an excuse to get the new race springs sooner 3-were getting new race springs when a good deal pops up
we'll see how it goes
-Ryan
1971ford
Post by 1971ford »
guys im trying to find some Rancho's for this,
but of course my truck has the stupid thread mounting deal up top. see the first picture, top mounting for shock.
whast with this? i thought there should be a normal mount on the rear (where the mount has a horizontal stub for the shock to slide onto)
-Ryan
oldschoolrods
1971ford wrote:thanks guys, maybe tomorrow ill have the short one out of both packs. got to buy some Rancho's too so i can get those in.
The U bolts need to be replaced any time the spring is removed. When you tighten a U bolt the thread is streched. Kind of a pain but they will not last if they're not replaced.
James72
Post by James72 »
If you're getting new springs anyways, why not just torch the ends off that bottom overload leaf? Then you don't have to mess around spending money on u bolts and center bolts that you'll just have to replace again when the new springs show up. :2cents:
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
1971ford
Re: re: which leaf to remove from the pack
Post by 1971ford »
James72 wrote:If you're getting new springs anyways, why not just torch the ends off that bottom overload leaf? Then you don't have to mess around spending money on u bolts and center bolts that you'll just have to replace again when the new springs show up. :2cents:
James
i like the way you think 8)
i shall remove the bottom leaf's, take them to the welding shop and cut them up. should i just leave 6 in. or so in the center?
-Ryan
James72
Post by James72 »
I suppose the more you cut off the softer it'll get, so maybe leave the 6" and if it's too stiff, take some more. Don't for get the video camera for the trial run :thup:
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
1971ford
Post by 1971ford »
James72 wrote:I suppose the more you cut off the softer it'll get, so maybe leave the 6" and if it's too stiff, take some more. Don't for get the video camera :thup:
James
pshhh like id go anywhere without the camera :roll:
ill get pics. im going into work tomorrow at 10, i MIGHT be able to get the leaf out before then.
but i just thought... im going to have to loosen the u-bolts quite a bit, and im going to have to remove the center bolt a ways... then remove the leaf, then put the partial leaf back in, retighten the u bolts and center bolt... isnt this going to just be like taking the ubolts off? would i need new ones? i dont want to have to spend money on them yet
here is a sweet concept photo of the master plan
-Ryan
