Spring questions
Joshpow
Spring questions
Post by Joshpow »
I was just wondering. Is there a difference between Big block and small block front springs. I was wondeing, because I am getting ready to convert my 72 to disc brakes. I am going to do a coil cut, even though I know thats not the proper or best lowering solution. I want to have a set of coils cut and waiting for my swap. The truck the fron axles,etc came out of was a 77 460 long bed. My 72 is a 302 shortbed. I think the front coils are different, but I want to be sure. Also, would a long bed 70 with a 302 have the springs I need,or are they heavier due to a long bed truck?
Thanks,
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
jengle
re: Spring questions
Post by jengle »
I think that Ford probably used different springs depending on both the engine and the GVWR rating on the truck.
If you cut a coil from the front it will be significantly lower and your alignment will be WAY off. It will handle poorly and the tires will wear out. There will also be a noticeable tilt to the wheels. On many cars, cutting a coil will work OK to lower it, but on I-Beam trucks it's a big NO-NO...JMO
wt4speed#2
Post by wt4speed#2 »
Chris's truck has cut coils, and drives and handles well,I have driven it myself. The alignment can be corrected.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
binder56jd
Post by binder56jd »
that wheel "tilt" is referred to as camber--just a polite fyi :thup:
now serving #235
Joshpow
Post by Joshpow »
I know all the cons, but I'll deal to lower it for now. It can't wear tires much worse than now! Current wear is horrible. Thanks for the advice. Anyone know a definate answer about whether there is a difference in the springs?
Josh
71 F-100 Custom SWB
02 F-250 Stroke
fitzwell
Post by fitzwell »
Tony, how much did ya cut out of those coils???
wt4speed#2
Re: re: Spring questions
fitzwell wrote:Tony, how much did ya cut out of those coils???
I'll have to look . I think I still have the cut off in the garage.
(note to mike: not ignoring ya just saw this and I'm not getting notifications to my e-mail addt for some reason. holler at me )
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
td
Post by td »
im guessing that the big block springs would be a little heavier spring, just me guessing though, and as far as cutting the spring i wouldn't say its a no no you just can't take off to much. if your using stock i beam they can be used to correct negative camber that would be created from the coil cut. i'd say 1 to 1.5 rounds cut max.
