so my 71 had dual tanks. i took the underbed tank out to put in my 69 which only had the incab. but the parking brake doodads are different depending on if you have the 2 tanks or not because the only-incab parking brake setup interferes with a dual tank.
i read in Keiths project that the lenth from the pedal to the setup that turns into two parking brake cables are different sizes.
so ive got to put the 71's cable into the 69, but what about the rear cables? the ones that go from the drum's to the doodad.
