The part that goes onto the gear box is a tad too small.
Anybody know where I can get a Pitman Arm for the Bendix?
HH
cdherman wrote:I should have been more clear in my post. It is well known that the pitman arm for saginaw PS boxes is different than the one used for manual steering. That is what is discussed in the above tutorial.
However, what I do not know is wheather the pitman arm is different with the Bendix powersteering unit. I have never heard that before, and I doubt it frankly, as it otherwise is usually referred to as a bolt in replacement for the manual box, with no other modifications needed.
But if it turns out to be true that the Bendix box requires a different pitman arm, then please someone do post that up.
