"rebuilding" my leaf pack
1971ford
Post by 1971ford »
im stripping my leafs and painting them and going to put them back together with new bushings and such, but what should i use between the leafs to help prevent friction?
the little wax paper things that were in there from the factory are history.
also is it ok to paint leaf springs with POR-15? it doesnt effect the way the leafs bend or anything?
and how do you remove the bushings?
-Ryan
1971ford
Post by 1971ford »
surely someone knows if i can paint them with POR-15........ and the other questions.
-Ryan
binder56jd
re: "rebuilding" my leaf pack
Post by binder56jd »
the paint won't affect the springs, although the springs may affect the paint--a brittle paint won't last on flexible surfaces--i am not experienced with por--but it seems i remember hearing that it has a brittle finish
now serving #235
1971ford
Post by 1971ford »
por-15 is very far from brittle, it dries rock hard. ive painted alot of stuff with it allready and its amazing how solid this stuff dries too. supposed to never chip/peal or anything.
it can also flex alot, so i dont see why it wouldnt be able to be painted on leaf springs (answered my own question :D )
-Ryan
AK F100
Post by AK F100 »
The best bet is to try it and let US know if it works. I'm sure some others had / have the same question. Good luck, give it a whirl.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
wt4speed#2
Post by wt4speed#2 »
Find a source for spring paint . Don't use anything petroleum based between the leaves i.e. grease or lube of any kind. Petroleum based products take the temper out of spring steel.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
You can see some pictures of mine here:
http://www.fordification.com/my67-p28.htm
I disassembled my springs, sandblasted 'em and painted 'em with POR-15. As long as you do the proper prep, the POR-15 should be good for a long time, and they won't damage the spring, it's just an exterior coating, and is VERY flexible, more so than more-common powdercoating.
The anti-squeak pad used between the helper spring and the rest of the leaves is actually a thick teflon (plastic)....but they do deteriorate. You can do a Google search and find that they're available aftermarket, though I would think you could find something around the house to use as a replacement, just cutting it to the same size as the factory piece. Mine were still in pretty good shape so I just reused the originals.
1971ford
Post by 1971ford »
cool thanks!
i missed all that spring rebuilding stuff, i just saw where you had a picture of the springs hanging in the middle of the page and thought that was it.
ill try to find new pads, the ones that were in the pack are now no more than a mm thick. they are wasted.
ill order a bushing kit from NPD and drill out the old ones. i dont have a air chissel though, maybe a chissel and a BFH will get the job done.
where did you get that bushing kit Keith?
-Ryan
I'm using polygraphite bushings from PST (www.p-s-t.com). They're like urethane but with impregnated graphite to eliminate squeaks.
http://www.p-s-t.com/pc-1182-592-ford-f ... 57-03.aspx
These required removing the outer shell from the factory bushings, but some hi-perf bushing sets need the shells, so don't remove anything until you have the new pieces in hand and read the instructions.
1971ford
Post by 1971ford »
wow $80.00 :eek:
what about this from autozone, is this what i need? i need all the bushings for my rear leafs andi have flexo matic. the picture is used for all their leaf bushings so dont go by that.
this is the all i need right?
http://www.autozone.com/selectedZip,956 ... ectZip.htm
-Ryan
Wes
Post by Wes »
Those will work, just remember to use a good silicone grease liberally as you put them to together.
Wes
67 F250 High boy
69 Bronco
1971ford
Post by 1971ford »
oh yeah it doesnt look like it comes with the grease
-Ryan
