Steering column wiring
I put a 79 steering column in a 68 f250 but I cannot get the wiring to hook up.Havin a hard time with turn signals and brake lights.Can anyone help ?
- Joshpow
re: Steering column wiring
I have a 78 tilt in mine. Here are the matches I used. There are alot of discrepencies, but this worked for me. I wired the plug that I cut off the 78 truck to the plug I cut off my 72 column and used it as an adapter. Here is a link to my post:
http://www.fordification.com/forum/view ... highlight=
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- flyboy2610
Welcome aboard!
Here is a page with links to wiring diagrams.
If you can figure out which wire does what in your column, you should be able to get it properly wired.
- td
look at the color of the wires behind the plug they should match really close. i did the same swap 79 to 68 and they all matched perfect, except the 79 had cruise on the collum, i just did'nt use it.
I have tried everything matching all colors with colors.This is not working.Would you happen to know which one is the ground wire?
- Joshpow
I believe the column is grounded solely by the bolting to the grounded brake pedal bracket and dash.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
None of the colors go together. What a nightmare! Ive tried everything I must be missing something?
- flyboy2610
Try this:
http://www.fordification.com/tilt.htm
- td
private m. sent.
