When converting from manual to power brakes do you have to change the brake pedal? Thanks
-Lance
brake pedal question...?
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
- ToughOldFord
re: brake pedal question...?
No. The brake pedal is the same for all '68-'72 trucks, regardless of whether it has manual or power, disc or drum brakes.
- SteveC
the only difference is in the booster which is
67 is a one year only style booster since the brake light switch is different and 68-72 is all the same
If you want i can post a link to when i upgraded my 67 with the pwer brakes if nothing else itll give you a idea off what needs done.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- seattle67
Nope, that wont work.Cowboy34 wrote:how about adding a brake booster to a 67 Ford F100 and the booster will be from a 78 Ford
Take a look at the following link. Once again, Keith has done all the research for us.
http://www.fordification.com/clutch-brake-brackets.htm
Dan
