sloppy 4x4 steering, need joint solutions
fomocoguy
Post by fomocoguy »
So, on the 4x4 the steering is a little loose, and I tracked the problem down to the joint where the steering shaft meets the gear box (right at the front of the box). It's worn and has a lot of play in it, and won't pass inspection that way. Do any of you know what the technical name for that joint is, and if they are still available? Thanks!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
flyboy2610
Post by flyboy2610 »
It's a steering coupler, or rag joint.
You can get them from a parts store, or you can get one from NPD.
fomocoguy
Post by fomocoguy »
I was thinking that a rag joint was the type with the rubbe disc inbetween to parts of the steering shaft. This one has the shaft going into it at one end, but i guess they call it the same thing...
Joe
2005 Ford Ranger
flyboy2610
Oops. Didn't catch the 4x4 part.
As Emily Littela would say "Ooooooooooooo..........never mind."
fomocoguy
Post by fomocoguy »
flyboy2610 wrote:Oops. Didn't catch the 4x4 part.
Here's a pic of the joint. Does anybody know where I can get one, or of something else I can upgrade to?
Joe
2005 Ford Ranger
Wes
re: sloppy 4x4 steering, need joint solutions
Post by Wes »
If you take it a part you find the shaft has a cross pin. The Pin holds to square bits of steel that slide in the channel of the cup half attached the steering box.
Inspect it you may get lucky and need only grease. If not you might be able to make something work for your Vehicle inspection.
Not sure if I kept ours will try to look around for it.
Wes
67 F250 High boy
69 Bronco
heep70
Post by heep70 »
I solved it by making one of these from two intermediate shafts and a newer slipshaft.
The u-joints aren't available any longer for the stock shaft, but I found u-joint used for a PTO application that works. I think it was a Precision 830. I can check that number if needed.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
fomocoguy
Post by fomocoguy »
Thanks guys! Is a slip joint needed in the steering, or could I just get one of these universal steering joints I found on ebay and use it?
http://cgi.ebay.com/ebaymotors/MOROSO-S ... enameZWDVW
Joe
2005 Ford Ranger
Wes
Post by Wes »
You could use that Moroso joint, it should fit the steering box ok. You will have to figure out a way to attach it to the steering shaft thou.
Wes
67 F250 High boy
69 Bronco
heep70
Post by heep70 »
fomocoguy wrote:Thanks guys! Is a slip joint needed in the steering, or could I just get one of these universal steering joints I found on ebay and use it?
It is good to have some sort of forgiveness in the intermediate shaft. I got mine slip from a newer F250 ou of a junkyard. I think it cost me $10.
Greg
fomocoguy
Post by fomocoguy »
I'm going to make an early morning run to the junk yard tomorrow. I know they have a 4x4 there, so hopefully it's got a better joint than mine. Either way I can scout for some others I may be able to use...
Joe
2005 Ford Ranger
