Problem with new brake booster.
derek7871
Post by derek7871 »
'68 F-100, manual drum brakes. So, I got a power brake booster from a member here. I finally got around to installing it today. Everything was going fine until I was finishing up and attached the booster rod to the brake pedal under the dash. When I got it attached, the pedal was super, super stiff. I tried to push it down and it would only go an inch or two. I thought with the engine running it might go back to normal. After letting the truck warm up a bit I tried to move....just as I thought, the brakes are fully applied.
I know there is an adjustment where the brake pedal attaches to the booster rod. I don't think this will help in my case. In some other posts I've read there is mention of an adjustable rod between the booster and the master cylinder, but mine had no adjustments.
Did I do something wrong?? Any ideas why my brakes are fully applied.
Cooter
what did the bosster come off of? the only adjustable rod is betweenthe booster and the pedal. not all of them had the adjustable rod though.
derek7871
re: Problem with new brake booster.
Post by derek7871 »
I think they said the booster came off a '71 or '72 truck.
thats strange. it should work properly if you have the correct brackets. where the brackets supplied with the booster? or were they off of something else. 67-77.5 brackets will fit and work properly for our trucks.
derek7871
Post by derek7871 »
yea, the brackets came with the booster.
can you get a pic of this brake pedal and rod where it hooks up. and are you sure it a 68 and not a 67 with a 68 door or something like that.
seattle67
Post by seattle67 »
Ya, pics may help.
Are you absolutely sure the rod between the booster and the MC is not adjustable? Mine is on my 67, and I had to do a bit of adjusting on it for things to work correct.
Dan
derek7871
Post by derek7871 »
100% sure it's a '68. i'll work on a picture.
Cooter
derek7871
Post by derek7871 »
Going out right now to double check the rod between booster and master cylinder.
derek7871
Post by derek7871 »
The rod between the master cylinder and the booster is not adjustable. It is, however, a little smaller than the one that was in the master cylinder. With the master cylinder removed from the booster, the brake pedal frees up and goes all the way to the floor. I got some pictures, but I have to figure out how to get them on here. Dial up stinks!!
In the picture the rod on the left in the one that I have been using. I can't reuse it because on the other end it attaches to the brake pedal and can't be put in the booster.
The rod on the right is the one that came with the brake booster.
did you use your old master? maybe it was catching on the inside of the booster somehow. or maybe its locked up or something. if its new did you bench bleed it first?
derek7871
Post by derek7871 »
Here are the 2 rods that go into the master cylinder.
The shiney gold one is the one that I have been using.
derek7871
Post by derek7871 »
Here's the picture of the rods.
derek7871
Post by derek7871 »
Here's a picture of the booster rod attaching to the brake pedal. The lock nut has been loosened.
Cooter
ford4x4fun
Post by ford4x4fun »
It should just work... I bought my brake booster new from Advanced auto parts when I put it in... Wasn't a problem.... Except, my roomate put it in, and didn't adjust the rod that hooks to the pedal correctly. I don't know how expensive they are, but I think I only paid 40 bucks for mine... Worst case scenerio, you go by one from advance and try it out. If you have the same problem take it back. If it works, talk to the guy that sold you the brake booster.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
