Small disk brake booster on 1965 F-100
winr
Post by winr »
I an gathering disk brake parts for my 1965 F-100 with manual drum brakes.
I have a complete 1977F-150 with power disk brakes and power steering.
I dont want to use the 1977 large booster with the brackets.
The brackets move the booster forwards about 4" and up an inch or two.
Is there a smaller booster that will bolt to the 1965 fire wall ??
Also, I am putting the 1977 disk spindles on the 1965.
Can I use the 1977 steering linkage on my 65 manual steering box ???
Maybe put the 1977 pitman arm on it also ???
Or ???
Thanks.
Richard.
All your Ford are belong to us
the small 67 booster is the way to go probably for a 65. you might find better info at www.fordtruk.com
