Disc brake conversion
H-DFord
Post by H-DFord »
HI I just bought a 69' ranger long bed. Drove it 420 miles to get it home. I have a 77 f100 for a donor truck. My question is this, do I use the brake booster and MC off the 77. And if so, will I have to change brake pedal or redesign it> Also one more question. I want to put new coil springs and shocks on front when I change it all over. Do I buy for a 69 or 77 year model? Thanks for any advice you can give me.
69F110
Post by 69F110 »
H-DFord,
If you haven't checked out this link...read through and see if it answers your question...I think it does.
http://www.fordification.com/discbrakes01.htm
I'm glad you found you a truck...a 69 Ranger no less! Sweet Action!
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
H-DFord
re: Disc brake conversion
Post by H-DFord »
I reread it and stilldid see it, but im printing it out and will read through it tonight again. I just did not see any info other than pulling booster & mc when I harvest other parts. But sometimes I miss details so ill try to study it out better tonight. And yes I love my truck. John
QC
Post by QC »
The brake pedal should work fine. Which coil springs you use depends on which radius arms you use. If you use the cast ones from the '69 you use '69 springs, if you use the stamped ones from the '77 you use '77 springs. The shocks should be the same for either one. You will need the steering linkage and pitman arm from the 77 or you will have to modify the spindles to work with the '69 linkage.
69 F-100 Ranger 302
As long as the donor truck is a mid-'77 or earlier, the booster will work just fine. Mid-'77 and later trucks have a different booster setup that will not work on earlier trucks. The master cylinder will work, up through '79. Your existing pedal will work as well.
Here are some pictures to illustrate the differences. If your booster looks like this, it won't work:
If it looks like this, it WILL work:
H-DFord
Post by H-DFord »
Thanks for all the replys. I'll pull my booster this week and check it against your pictures. Thanks again John
texasagchuy
Post by texasagchuy »
Besides the manufacturing process is there a major difference between stamped and casted radius arms? Any dimensional changes?
Are the ratings for the springs for a stamped radius arm different from a casted? I am trying to figure out if I can use the springs in my 66 with the 79 spindles, radius arm, and i-beam I found. Thanks. :?
Chuy
63 F-100
66 F-100
MadMaxetc
Post by MadMaxetc »
I do not agree with the statement that the springs are differant.
The local truck shop here told me that they are all the same part number. Only 2 numbers for an F-100/F-150 through F-250 2x4 '65-'79.
One For I-6
One For V-8
They said that the differance in the arms does effect the alignment a little, but is fixed by getting a propper alignment. ($67.00)
Dan
FORD Girl
Photobucket Pictures
iamthewreckingcrew
Post by iamthewreckingcrew »
I put 77 I-beams on my truck. I used the 68 radius arms and 68 springs (original 6 cyl).
The 77 I-beams looked the same to me. They sure don't look like "stamped steel".
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
when using the springs from one set of ibeams you need to use the spring cups that match the springs. if you use a dentsides spring then you need to use the dent side lower cups also.
AlleyCat
Re: re: Disc brake conversion
Post by AlleyCat »
iamthewreckingcrew wrote:I put 77 I-beams on my truck. I used the 68 radius arms and 68 springs (original 6 cyl).
All the I beams are forged steel.Our trucks also have forged radius arms.73-79 radius arms are stamped steel. :)
Clay
iamthewreckingcrew
Ahhh...OK
Maybe I read something wrong up there. Yes the radius arms on the 77 were formed, or stamped steel. Thanks for straightening me out. :D
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
H-DFord
Post by H-DFord »
Ok I finally got to check my booster and MC . And it will work. So now I just need to start pulling parts. My plan is to replace alot of the front end and I know my MC is bad. So for now ill pull parts and buy new parts as money allows. Thanks again for your help everyone. John
