Ok to start you have to remove the bolt holding the push rod. On mine it took a 3/4 offset wrench and a 9/16 socket or wrench.
i had to drop my ac unit to get a good angle to get to the back side of the bolt going through the peddle
Ok you cant see it in the pic but here is the brake light switch with the bolt i just removed from the peddle. There is the bolt a plastic bushing and a plastic ring that fits snuggly over the round part of the bolt towards the head of it. the bolt goes into the stop light switch then the plastic bushing goes inbetween the tabs on the switch and the bolt continues through the tabs where is is head in place by the ring that snugs over it and that bolts to the peddle.
here is a burry(sorry) picture of the push rod that just fell out of the master cylinder when i removed the bolt
here is the old master cylinder you need to remove the 2 bolts on on each side holding the master to the fire wall also need to remove the 2 bolts directly above the ones holding the master to the firewall.
OK looking back it would have been MUCH easier to probally put the brackets on the truck first but i never do things the easy way anyway you can see were this will bolt up as well as how the brackets go on the booster
Ok here is the booster attached to the firewall by the 4 bolts and dad finishing tightning them
one of the last things to do after bench bleeding the master cylinder attach it to the front of the booster and attach the brake lines carefully i had to pull on mine a bit to get them to reach probally a good idea to bleed your brakes as well
and you need a 3/8 inside diameter hose around 30 inches long to go over to the intake manifold you dont need quite that much hose but it never hurts to have a bit extra I circled the spot that is needed to tap into If you have a automatic you will need a brass T fitting to split the vacuum lines if you have a manuel jsut tap in here for vacuum. You could also tap into one of the rubber lines from the auto tranny line but it was to hard for me to reach
OK if i missed anything let me know
