Highboy frame width vs 2x4/4x4 F100
71PA_Highboy
Post by 71PA_Highboy »
OK,
Keith has a table on this page:
http://www.fordification.com/chassis_bu ... ntside.htm
I thought the Highboy was different, but my memory is not what it used to be.
Please set me straight.
Thanks!
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
averagef250
Post by averagef250 »
For bumpsides, the frame widths are all the same. For dentsides, the highboy frame was narrower in the rear than the F-100 and F-250 2wd, but the same as the F-350 and heavier 2wd.
Basically, the highboy and F-350 frames are almost the same, the highboy frame is actually a bit stouter up front. Those two frames stayed the same from 67 through 77. The lighter frames were changed and got wider in the rear in 73.
