rear disc brakes
1971ford
rear disc brakes
Post by 1971ford »
how difficult is it to swap in a REAR disc brake setup? what would be involved? and would it be noticably different? :?
-Ryan
mljjones67
re: rear disc brakes
Post by mljjones67 »
Personally I think its unnecessary. If they are in good working order you shouldn't need them! :2cents: :2cents:
heep70
Post by heep70 »
I have built them before for a D60, a 14 bolt and now doing a set for my 80 Toyota.
Built the backing plate using 3/8" and a spacer using 1/2"
78-88 Rear cadillac Ederado calipers w/ E-brake
86-89 Front Chevy Light 4X4 Vented Rotors 1" Thick
You can also use Ford rotors but the spacer thinkness I believe changes to 3/8".
Here is a pattern that was kinda like what I did.
http://www.moparmudder.com/images/bracket%20print.pdf
There are lots of folks out there now that sell kits to do this swap.
The pics below are of the 14 bolt without the E-brake caliper.
Image[/img]
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
kentdaryl
Post by kentdaryl »
Heep, are you building stuff inside your house now? Good for you, it's too cold to work outside! :thup:
mljjones67
Ok they might not be needed but they sure look cool!!!!!!!
4th effie n counting
Post by 4th effie n counting »
does the lincoln rearend have the correct bolt pattern for our wheels? (stock wheels)
67 F100 240 I6 3spd now gone :(
1971 F250 LWB FE power by FORD
heep70
Re: re: rear disc brakes
Post by heep70 »
kentdaryl wrote:Heep, are you building stuff inside your house now? Good for you, it's too cold to work outside! :thup:
I have built a couple wheelers in my house. Warm, dry and close to the recliner :P
Greg
1971ford
Post by 1971ford »
4th effie n counting wrote:does the lincoln rearend have the correct bolt pattern for our wheels? (stock wheels)
yeah, lets here more about this lincoln rear end. what models of lincoln will work? same bolt pattern? bolt on swap?
-Ryan
427blackpearl
Post by 427blackpearl »
i think the linc. rear has a different bolt pattern. you can also use explorer rear disc, i did the swap on a early bronco a few years ago,i used the kit from B C BRONCO it was nice, i am going to use it on my bump in a few weeks. i think the kit was less than $400. it used caddy calipers w/ parking brake jeep rotor. try B C BRONCOS.COM under brake system
heep70
Post by heep70 »
Here is the disk brakes I just setup on the rear of my Toyota wheeler.
Greg
71PA_Highboy
Post by 71PA_Highboy »
If you are doing this on your F100, the use the Exploder conversion.... that way you will have a useful emergency brake. Check the Early Bronco Forums (classicbroncos comes to mind).
No, none of the Lincoln disks have the same bolt pattern, but they did come on 9", so it is a reasonable swap... just have to re-drill the rotors.
On the D60, I haven't found a kit with a GOOD (read effective, simple and low maintenance) E-Brake. The Caddy/GM calipers with e-brake always seem to have issues over the long run.
JMHO,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
green70
Post by green70 »
the problem with explorer brakes is that they are to small to work with the truck bolt pattern,trying to find something that uses the 5x5.5 bp is the hard part,this company uses the cadillac calipers that have e-brakes built in along with redriled gm rotors ,theses are what ill be using,i was able to get the calipers at work fairly cheep so ill be into the whole set up for under 400.00
http://www.steeltechsolutions.com/REAR_ ... _CODE.html
71PA_Highboy
Uhh.... That is not completely correct Green70.
The Early Bronco is a 5x5.5 and people use them all the time... Check on the bronco forums I mentioned.
Many of the folks using them have converted from the GM stuff because of the ebrake situation.
If you don't use an e-brake, then it doesn't really matter.
JMHO,
Eric
Got Ford?
1 Lincoln Mark VIII
Mooosman
Post by Mooosman »
You can also try TSMMFG.com. They use a Ford rotor (I think a 4wd type slip on rotor) instead of redrilling GM ones. This allows you to pick up rotors anywhere. They use Cadillac rear calipers, which will hook up to your stock parking brake linkage.
I plan on using their kit for my 72. And adding a power brake booster. It should stop on a dime and give 9 cents change! :thup:
Nick,
Is tired of working on drum brakes! :eek:
1972 F-100 Custom SWB
