all i can do is
what kind/brand
approximate cost?
for a shadetree mechanic is that easy enough? or should i pay someone to do it for me?
Thanks again for everything.
So true...fitzwell wrote:Replace???
Everything?
If you are a fairly competent shadre tree, this isn't hard work. What it is , is nasty! I Hate drum brakes. Best advice i could give you is get a Chiltons, or a Haynes manual, & read the procedure before you tackle it.
If it's drum, leave one side intact while you do the other side, gives you a road map so to speak. Take your time, and remember on assembly, cleanliness is next to Godliness
