need to replace both curled lines that come out of the l/c and down to the drum dist block. what is the best place to buy these from i checked DC and LMC i see NPD has the whole set but i only really need the curled units.
ill admit i broke one line when i was removing the m/c to put my booster brackets in
Why not just make 'em yourself? Total cost would be about $10 and maybe 30 minutes tops to make and install them. You just need some 3/16" brake line from any parts store, and a double-flare tool. You could probably reuse the fittings on each end if you wanted to pinch pennies, but they're only a few cents apiece, so why not put something shiny in there. Heck, I completely did ALL new steel brake lines on my '67 with new lines, fittings etc for less than $30.
Any NAPA, Carquest, etc. is going to have straight line in varying lengths in stock. I just called my local store and was told they have them in stock with lengths ranging from 8" to 60". A 60-inch piece was a whopping $3.86.
Incidentally....you didn't need to remove those lines to install a booster. You simply had to unbolt the M/C and gently pull it away from the firewall, install the booster, and then reattach the M/C to the booster.
Oh well....right?
yeah i know i read you jigger on the tech page. but the one line was semi kinked and when i pulled it away after i disconnected the bracket from the steering box it kinked it more and started leaking. so know i have to decide if i want to go with a sing or dual diaphragm booster and whether or not to get a new M/C
I had mine bent up by the local hydraulics shop for $25 total. I havent installed them yet, but they look good! I will be going back to them for transmission lines later on.
is that the whole set of steel ones or the curled ones?
NPD had em for $25 but seems as though they reamed me open on shipping. cause the total was $44 and change cause ya know there custom CNC laser controlled factory spec'd made
