whats the cost to lay frame?
kilog55
Post by kilog55 »
i imagine its in the upper single digit thousands. if its too much anyone have before and after pics of bolt on drops? is 3" that noticable or not really
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
customcrewcab
re: whats the cost to lay frame?
Post by customcrewcab »
alote of things factor in. how? what your going to use front and rear. who? are you doing it or you paying someone?
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
kilog55
Post by kilog55 »
probly DYI not too many shops around me. whatever is safest and retains drivability
customcrewcab
well safe for driving i would go with a 4 bar in the back. i have ladderbars beacuse i want to hook up with a turbo stroked small block. i would do a mustang II under the frount. think the cross memeber was 500 to 600. they have tubular arms and spindles new on ebay pretty cheep. i think you will be happier with it in the long run.
F100builder
Post by F100builder »
You can always just get the crossmember for the Must. II and use wrecking yard parts from a donor Must. II to put it together for now. Then, as you can afford, you could upgrade to tubular arms, dropped spindles, etc. That's how I did the Must. II on my '56. Those complete hub-to-hub kits DO cost a fortune and even more if you start adding on options. Try giving Fatman Fabrications a call. I'm sure they're a little more now and I don't know what they cost for a bump but I paid about $380 for my crossmember kit many years ago.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
