spoungy brakes, bad master cylynder?
kevs250
Post by kevs250 »
recently I changed my front brakes, i have a 70 F250 with front discs. before and after i changed the brake, the pedal was spoungy and i was able to press the pedal to the floor and still not stop, and bleeding the brakes didnt help either. soo my guess would be the master cylynder.
soo if you guys could give me some input, that would be awsome 8)
Creecher88
Post by Creecher88 »
It could be either the master cylinder or a leaky line. Make sure to check the line to make sure. They may be wanting to stick, maybe try to clean the master cylinder out.
-Kevin-
68 Ford Pickup and a 2002 Ford Ranger Tremor
bugser
re: spoungy brakes, bad master cylynder?
Post by bugser »
I could pump mine for awhile, then it slowly sank to the floor. Not all at once, just a little closer every day. Then one day when I got to work...... :eek:
Fortunately I have AAA. :thup:
RON
Excuse me while I whip this out
basketcase0302
Post by basketcase0302 »
kev,
I would agree with James...this usually is a sign of air in the hydraulics of the brake system.
Get a "Mityvac" tool and start from the farthest wheel and bleed the lines again.
Basketcase
Wes
Post by Wes »
I'm going to say if not external leak your master is by passing and needs to be replaced.
Wes
67 F250 High boy
69 Bronco
FLATBEDFORD
Post by FLATBEDFORD »
How about bad rubber lines. Haven't I read here that when they get old, they can flex under the pressure and make the brakes feel soft?
Steve
My Photo Gallery
kevs250
Post by kevs250 »
ive checked for leaks in the lines but i found all the lines to be in OK condition, and like james was saying, i pump up the pedal and build pressure but when im stopped at a light the presure in the pedal starts to slowly go down and the pedal sinks to the floor. soo I think Im goin to replace the master.
