Frame question???
Frame question???
Hey,
I have a '72 F-100 SWB and the PO chopped the frame and I want to find a solid frame to go under it. My buddy has a line on a '73 shorty frame and I was wondering if it would work or not? Is there anything I woulh have to modify? The guy wants $250 for it so thats not bad.
Thanks for the help,
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
re: Frame question???
Never mind. Maybe if I would read the articles that Keith put together I wouldn't be asking dumb questions like this. So basically the frame is wider so I would need to drill new holes in the bed (as if it doesn't have enough already) and get a different rear axle to go with it. So I think I will hold out for a '67-'72 so there won't be any modification nessesary. If anybody has one that they want to get rid of let me know.
Thanks,
Corbin
Thanks,
Corbin
- AlleyCat
Corbin, unless you are going for a stock restoration a 73-79 frame may not be such a bad idea.If you could locate a rolling chassis, preferably with power steering you would get a new frame and 3 major upgrades at the same time.
Clay
Yeah the adapter plates sound like a good idea if I were you use the '73 frame. My buddy has a another line on an entire '72 shorty for $500 that I might take or try and get just the frame. I the '73 was a rolling chassis I probably would take it but its just the frame so there are several other things that I would need to find to go with it. I don't know i will wait and see if anything comes through in the next week or so and then I will decide.
Corbin
Corbin
Anybody now how much a bare shorty frame weighs? I found one for $200 that I want to get this weekend. I just wanted to know if it would take more than 2 guys to get it on the trailer.
Thanks,
Corbin
Thanks,
Corbin
Ok, thanks maybe the guy has a forklift or something. I'll get a couple of friends to help me take if off the trailer. Thanks for the heads up.
Corbin
Corbin
- 69bumptruck
Re: re: Frame question???
I loaded one with just 2 people. I've since moved it by myself too. Easiest way is to put a dolly under the front (it's heavier because of the crossmember), lift the back and roll it around.green68250 wrote:Anybody now how much a bare shorty frame weighs? I found one for $200 that I want to get this weekend. I just wanted to know if it would take more than 2 guys to get it on the trailer.
Thanks,
Corbin
One person is possible, just easier with 2.
- MadMaxetc
I have moved a bare frame by myself (I weigh 150# soaking wet) If it has the suspention on it then you will need 4-5 guys.
Make sure you get a good title for the frame. and check to make sure you can get it taged.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
